Buzz/Whine Back
Buzz/Whine Back
I had a " professional installer " who " knew" C6 Corvettes install my sub amp. He tapped the RCA signal from behind the radio, tapped the fuse box for power and turn on. After it was all hooked up, it sounded good but there was a little buzz and whine. I bought the ground loop isolator and it fixed it. It sounded great for about a month. I just got the buzz/whine back and it was a lot worse. Another forum member said the GLI might be bad. I took out the GLI and the problem was still there. I've never connected the power to a fuse box inside the car before. Could that be the problem? Could it be the RCAs behind the radio? It worked great for a while so it's got to be something that just went bad. Any ideas? Thanks
Found it
I was planning on rewiring everything. So I started to disconnect the amp. Power, turn on, RCA.s. I got it all apart and the bad buzz/whine came back. So, it had to be the way he wired the RCA's off the OEM HU. I got to it and it was a loose wire. Got it all back together and sounds good again. My goal is to get a 4 channel amp and run my 6.5 Focal Components and this sub and be done. Thanks for your help. I'll watch the GLI.
Thought I fixed it. Definitely a loose RCA wire from the radio. Installer said he's fix it no charge. Not sure I want to do that. What about this AOEMGM24? Looks like it's plug and play, ready to go. Any good? Is that better than making your own one with an AddGM24?
If you have the ability, make your own with the AddGM24.
The AOEM works fine, but the sound is passed through electronics. Not much of a change, but many have reported that they can definitely tell, and they don't like it.
