Help with Bluestar aftermarket bluetooth
I have an 07 Z06 with a Bluestar 2010 handsfree system installed (I assume since it isn't working). I just bought the car and the second owner I bought the car from didn't use it himself so he couldn't help. This is a really simple system made to make use of the Onstar buttons on the mirror as you replace the Onstar module with the Bluestar one.
I don't have active Onstar and i don't want it so no big deal if that was removed, but I can't pair my Z30 with it. Specifically the Bluestar does not even appear on the list of available devices that comes up on the "find Bluetooth" result on the phone. One thing I notice is the compass direction light on the mirror works with the on-off button on the mirror, and the little green light on the left lights up, but there is no back lighting on the Talk, Multi-Function, and Mute buttons. Based on a youtube video of a guy installing the same unit on his 07 GMC, there was backlighting on his Onstar buttons so I would expect mine to also be backlit. Does it seem like this absence of backlighting might mean a defective Bluestar module or bad connections?
Also how do I access our Onstar module? I see on the Z06 it appears to be under the passenger seat. Is it best to access it from the front, the back, or remove the seat? Should there be enough wire slack to pull the thing into view while still connected? Thanks for any responses.
