Alt whine
Alt whine
Have focal is200 components and arc audio 5029 on a kenwood xr400 amp along with a nvx mini monoblock amp for the sub on a stock nav hu. Used a aggGm harness and added rca jacks. Used y-jacks to split signal to the two amps.
Here is the problem. Get the alt whine thru both amps when i hook up the right rca lead to the nvx sub amp. The whine will go away from both amps if i take it off. Rca lines run by tunnel power by passenger door.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
When Installed upgraded system in my C4, I also had whine from the Alt, I bought filters for the RCA jacks, which cut it down to nothing. Then I started chroming out the engine compartment and chromed the Alternator, which stopped all noise and removed the filters.
Wish I can tell you what kind I used, but I like to throw thing away, sorry.
You need filter for each RCA cable.
Hope this helps you little.
