Rockford Fosgate P3SD2-10 in a JL Stealthbox C6
Cruising
Hello!
I have a JL Stealthbox with a JL10W3v2-D2 sub powered by an Arc Audio Mini KS 125.2BX2.
Can I replace the sub with a Rockford Fosgate P3SD2-10? Mounting depth will not be an issue in that box. The cutout diameter of the P3SD2 is 9.06 inches. JL shows the mounting hole diameter of 9.125. I don't believe this means the same thing so it's possible the P3SD2 will not mount correctly?
If this drop in replacement will not work, can anyone recommend a sub that will?
thanks!
thanks!
