Nav for base radio swap -Expert Advice Needed
With apologies in advance I am posting this in both the "General" C6 discussion forum and in the Audio forum in the hope doing so will give me a better chance to garner some expert advice.
I have a 2011 C6 with the base radio/single CD player. This is NOT a Bose system. The car, however, is also equipped with radio controls on the steering wheel and Blue Tooth, although the latter is needed for my phone, only (and I don't care about having On Star).
My question is whether or not it would be possible to easily swap this unit for a GM Nav with CD unit (which I understand only came with the Bose system). I know I have to get a dealer to unlock it once installed, but my hope is that the installation would basically be a plug and play, with all functions listed above working once the unit was in place and unlocked.
Any experienced guidance would be greatly appreciated.
If you do go with the GM Nav it SHOULD be a drop in replacement. I haven't seen anyone post that it didn't work, and plenty that it has.
You'd need a new GPS antenna if it doesn't come with one, and if you currently have XM your old box probably won't work with the new radio (XM box is supposed to be 'married' to radio when first installed, and they can't be reprogrammed).
Once installed the new radio should operate fine in Accessory mode before the car gets started, but once you start the car it will go into security lockdown until a dealer reprograms it.
By most accounts, even a used aftermarket unit that's several years old is better than the GM Nav
Just an FYI...at least in my case. The XM receiver was not married to the radio. I did the swap to factory NAV and it has worked with no issues. Just remarry the NAV to the Vehicle VIN and you're off and running.
Steering Wheel Controls
I have been offered a 2007 Nav to replace the base radio/cd in my 2011. As I have steering wheel controls and the blue tooth will either/both be functional with the 2007 nav?
Cancel away, BT will still work just fine
