Couple of Questions about 1988 Install
Ok, I have decided to pull the system and start over. This means new head unit and front speakers. The previous owner had installed 6x9s in the rear and used the stock system (which played a terrible high pitched noise at all times and only played music from one speaker). The install if going fine when I have time, but I have a couple questions.
1. With my order I got a Metra 70-1677-1 - everything looks fine, but I have a separate connector with a yellow and an orange wires. One of them matches up with the aftermarket player and the other one is labeled dimmer and does not have anything to hook to.
2. My order came with a Metra 40-GM10 Antenna Adapter - I have tried to install but the prong from the car feels like it is going to break off. Is this the correct part?
3. I am trying to run new wires to the rear speakers to bypass the factory stuff. I think they can be run down the center but have hit a snag behind the console. Any advice?
Thanks everyone
Thanks everyone
Thanks everyone
Thanks everyone
2)I don't think you need it. the antenna connector in the car should plug into the radio without issue. the CDM in the 90-newer has a smaller antenna plug that the adapter you have would plug into..
3)what type of snag? at the back of consoel, i would then run one wire to the passenger side and one to the driver side along that 'partition' then to the respective speakers
1) aftermarket player might not have a dimmer input. some radios will adjust as you adjust the dash light brightness.. many aftermarket decks are just on all the time without this feature
2. I am not sure that it will reach
3. I cannot find a clean place to get it under the carpet to run over/through the partition.
Thanks for your responses.
2) antenna cable should reach on the 88 without issue (you have a picture of it?)
3) again in the 88 run it to the sides and follow it over on the 'wheel well' humps
