C5 Radio Upgrade Double Din
Hello guys!
I am planning a stereo upgrade for my 2000 C5 Corvette. I want to replace it with this unit
http://www.ebay.com/itm/361068662653
It seems to do all the things I want, and is in the right price range.
The car has all stock wiring, and I am going to attempt to do the 2 Din modification of the bezel myself.
I am a little worried about the wiring for this thing. What sort of things might I need?
It has an "ISO" port on the back, as well as some RCA plugs.
Thanks for the tips!
Hello guys!
I'm in process of putting a similar unit into my '96. Assuming the 2000 has the BOSE receiver behinde the seats, check out Metra for a interfacing cable one end plugs into the receiver, the other end the new unit replacing the Head Unit in dash.
I've picked out the following adapters so far:
Metra 70-1858 Radio Wiring Harness For GM 88-05 Harness
Antenna adapter
And this I wasn't sure if I needed or not:
PAC AOEMVET-1
I think I still need an adapter to go from what ever that ISO port is. Although I may end up simply cutting it off and soldering the wires directly to the GM adapter.
Last edited by johnodrake; 10-31-2014 at 03:33 PM. Reason: Delet non supporting vendor links
If you're keeping the stock door speakers and subs functional, then you do need an adapter unless you want to do a lot of splicing on the oem wires.
The AOEM is for keeping the stock radio and installing new amps/speakers. Along with the dash mods, you would need the ROEM and an antenna adapter.
I posted a link to an FM antenna adapter, but apparently we can't post links to Amazon. oops!
I have JL Audio speakers in the doors and rears, but don't have a new amp or sub yet. I am trying to work through one upgrade at a time right now, and the next on the list is the factory head unit.
