Sponsored by: DashLynx
oem bose need help
Old 10-31-2014, 06:52 AM
c31980
c31980's Avatar
Default oem bose need help
c5 50th ann. with cassete oem bose unit .i got bose cd readio from another c5 after installing it
it work fine load the cds radio chanels are ok ,,, but with no sound
or very very low sound .got another bose cd unit and the same issue
going back to the cassete radio evey thing work fine
have chekd all wires oem speakers every thing look in order
so.. what iam missing ?? the po had installed dd unit and when ibought
it was with oem bose cassete
any help or guide lines will b appreciated ..regards
Old 10-31-2014, 04:38 PM
markcz
markcz's Avatar
Are there any plug ports on the back of the CD units that aren't being used when you install them in your car?
Do your doors have the 'Bose' emblem on the speaker grills? If not, you wouldn't have the Bose processor installed, so if the CD units are set up for Bose the car wiring would be different.
Old 10-31-2014, 06:49 PM
c31980
c31980's Avatar
Thks Markcz
yes only one port is blunk its number 3 port next to bat+ and ign12+
yes there are emblem of bose on each door and there were some after market speakers
connected bypassed the orig hareness so .. i replace them with ome bose spreakers all 4of them and connected the main original harness and both cd units i tried are bose
09390211,16257601 also ..the cassete one is 16194461
Old 11-01-2014, 03:20 AM
markcz
markcz's Avatar
To oem bose need help
Quick Reply: oem bose need help
