C6 drivers side Bose sub cuts out
While driving my C6 and hitting bumps in the road. My driver side Bose sub cuts out. I cut the stock head unit on/off and that usually turns it back on until the next bumping road. I swapped the left and right door sub to see if the sub was bad. Same problem with the driver side. Wiring going bad? Any advice? Thanks
C6 prints are HERE if you need them.
Others have had issues with a broken wire in the door accordion. With the radio playing, open the door, pop out one end of the accordion gizmo, tug on or wiggle the wires to see if you can recreate the problem. If you can find and isolate a break you could easily fix it with a splice.
