08 nav, sound cutting out.
Hello and thanks in advance....
I have an 08 auto with the stock nav system...sometimes, mostly my left speaker, will cut out if I hit any bump what so ever. Hard turns can also make it cut out. If I give a hit with my right knee to the side of the radio, it will come back on...Seems worse when it is cold outside and radio has been on for a while (30+ minutes). I know something is loose,obviously, but not sure what and how to fix it? I can't be the only one that has had this issue?
I would start with the door, with the radio on start tapping on door panel and accordion tube and see if you can get it cut out. My guess is a loose or broken wire inside the door panel.
thanks
My mistake if both are doing it then that points to the connections at the head unit. Same principal but now you have to gain access to the rear of the head unit which is not that hard. When you have it loose just wiggle the wire bundles one at a time to see if you can locate the loose connector or broken wire. If you cannot make it repeat then the issue may be in the head unit itself.
