Sponsored by: DashLynx
Double din in dash
Old 01-29-2015, 08:10 PM
AndyK
AndyK's Avatar
Default Double din in dash
Hey Guys, new to the C6 world and bought a Pioneer NEX. When it comes to the installation kit/trim is there a preference over scosche or metra? Also What is the correct wiring harness for a 1lt without onstar or bose? The only other item I need to buy is the antenna connector correct? Thanks for the help!
Old 01-31-2015, 02:44 AM
striper
striper's Avatar
Since no one else has replied, the best advice is to go DoubleDMods, a vendor here on the forum. He will supply you with everything you will need to do the easiest and best conversion, all at the best prices too.
Old 01-31-2015, 03:44 AM
markcz
markcz's Avatar
I would go with the Metra, the newer model matches the oem dash better.
Several choices, but BEST option for you IMO is the C2R-GM24
Correct. However, since you'll be doing all the other work, adding a backup camera would just take a few more minutes
Old 01-31-2015, 03:47 AM
markcz
markcz's Avatar
Everything in one box HERE
Old 01-31-2015, 02:39 PM
0Double D Mods
Former Vendor
Support Corvetteforum!
Double D Mods's Avatar
St. Jude Donor '12-'13
The RP3GM11 replaces the cr2gm24 now
I have them just dont have website changed LOL
the rp3gm11 has the reverse connection the c2rgm24 does not have
Old 01-31-2015, 04:09 PM
markcz
markcz's Avatar
I just got used to the C2R-GM24 replacing the GMCO
To Double din in dash
Quick Reply: Double din in dash
