Bose With Nav adding a Subwoofer
Hi everyone,
Wanted to put this Kenwood 8' compact powered Sub in my 07. What is the easiest way of hooking it up? I hear you can tap into the rears for line level but some say that wont work while I hear others use the PAC ADD and tap in behind the head unit
Just want to use the simplest easiest way without messing things up
http://www.crutchfield.ca/Kenwood_KS...113kscsw11.htm
http://www.sonicelectronix.com/item_...-ADD-GM24.html
