C5 Oversized Double Din
Hey Guys,
I was wondering about a slightly bigger than normal double din radio in my C5 2000 coupe.
According to the dimensions in the picture it should still fit into the radio slot. But the front panel is larger than the standard measuring in around 201mm by 120mm, with a little extra on the sides for mounting.
I am hoping this larger front panel will have a closer to factory look, and match the factory bezel opening a little better than many standard double dins do.
Any tips or advise is appreciated!
~thanks
~thanks
