Installing OEM Nav in Non Nav C6
I've found a good buy on a virtually new 2010 OEM nav unit. But I'm not sure if it will work in my car.
I have a 2007 with Bose, steering wheel controls, no nav. What will i have to do to install the 2010 in my 2007.
There are many detailed threads for this, some may even be stickies over in C6 gen.
You'll need a new GPS antenna, then after the install you'll need to take the car to a dealer to have them program the radio to the car (it won't work with car running until you do).
Unless the oem Nav is $200 or less I'd still recommend an aftermarket unit over oem
