Sponsored by: DashLynx
C5 Double Din Install Guide (Radio/CD Upgrade)
Old 05-12-2015, 05:55 PM
axman
axman's Avatar
Default C5 Double Din Install Guide (Radio/CD Upgrade)
I posted this in the C5 Forum for anyone looking for a how-to guide on how to do a fully loaded Double Din install.
https://www.corvetteforum.com/forums...d-upgrade.html
Old 05-12-2015, 10:11 PM
Mike Beck
Mike Beck's Avatar
Looks almost the same as mine. I did this at home, wasn't easy, but came out fine.
Old 06-09-2016, 07:08 PM
axman
axman's Avatar
I figured out the RFASWC programming!
This works with Apple Car Play / SIRI:
Start:
Power off Car, open door. Close door, turn key to ACC.
AXXESS will flash LED red to indicate power is on.
Hold paperclip in reset hole in AXXESS box for 5 seconds depressing the button as you hold it, release.
LED will begin rapid flashing while it scans for the radio.
LED flashes 6 times to indicate Pioneer Radio. (Number of flashes may vary for your radio brand.)
LED stays on red.
Push Volume Up (I use Up Arrow on RFASWC)
LED goes out.
On the Pioneer Head Unit, Hold Volume Down so you don’t blast your ears.
At the same time, on the RFASWC, Hold Volume Up (Up Arrow) for 10 seconds until the LED stays red. When you release Volume Up, the LED should go off.
Press RFASWC keys as follows:
(Red LED will light while each key is pressed and each key must be pushed for at least 1 second. Red LED will go out when key is released.)
Down Arrow (Volume Down)
-> Right Arrow (Seek next)
<- Left Arrow (Seek Previous)
Source
Mute (Button on back)
Press Volume Up 4 Times to skip assigning the following:
Volume Up (Preset Up)
Volume Up (Preset Down)
Volume Up (Power)
Volume Up (Band)
Red (Play/Enter)
Green (PTT Push to Talk)
Press Volume Up 6 Times to skip assigning the following:
Volume Up (On Hook)
Volume Up (Off Hook)
Volume Up (Fan Up)
Volume Up (Fan Down)
Volume Up (Temp Up)
Volume Up (Temp Down)
Led should do 1/2 flash indicating you are done after 6th Volume Up.
If you made a mistake, to back to Start. When completed- Red button does nothing, Green Button is Voice Activation / Siri button. Push the green a second time to cancel Voice / Siri.
To C5 Double Din Install Guide (Radio/CD Upgrade)
Quick Reply: C5 Double Din Install Guide (Radio/CD Upgrade)
