Adding Sirius and Mp3 to Factory Head Unit in C5
I have a 2002 C5 with a factory head unit. It has a Cassette, AUX button, but no CD. I have already installed an FM modulator to use my Sirius Sportster 5. I get static in the background that I can mostly hear when I change channels. I was looking at the PXDX to try as a direct connection to see if that eliminated the static by using the 3.5mm connection instead of the FM modulator. It seems like I can use it with any Mp3 player, and it looks like I can connect my Sirius as well via the 3.5mm plug. I guess I would have to physically plug/unplug every time I wanted to switch between sources, or is there something else I should be looking at as an option? Thanks in advance.
