Just want a USB port.
Info missing before that can be answered...
Year?
Does it still have the OEM HU in it or not?
Most can be wired to work. Go to Ray Kawal's webpage and look for your answer there. C5 and 6 are not an issue and you can get necessary harness or components directly from him.
Year?
Has asked for a USB input not an aux audio input, only way to do it is to change out the radio. However, in C6 you can install a newer version of the stock radio.
for what purpose and to what equipment?
if for power only use, yes, i have in a couple places. (i suspect as have others here its for radio/music use since you called it port, and your in audio section) here are mine added, but they supply 5V only for power purposes.
