Good ground location on/near the rear wall for an amp?
I'm installing an amp on an amp rack and need a good ground location on/near the rear wall? I've looked at a ton of install photos on the site and have not seen a picture demonstrating a ground location in the back yet.
Any suggestions?
Any suggestions?
Did you have to drill or was there a grommet available? Am I looking into the wheel well on that last picture you posted to your thread, I'm not quite clear on the orientation of the picture.
This is literally the last thing I need to do, I tested my system with a temporary ground and I'm good to go once I sort out the ground situation. I'd hate to drill any holes if I don't need to, I managed to avoid that with the power wire thought the firewall.
Be careful. If you used a ground that has a smaller wire from wall to frame than the wire from amp to wall you may end up with issues.
Drill a small hole in the wall and connect amp ground directly to rear bumper just inside inner passenger brake light housing.
