Speakers cut out
Speakers cut out
I added a LOC spliced into my Bose Amp and wired it to only the rear speakers. The remote wore is wired into the white radio antenna wire. I tripled checked avert thing and the grounds but after a few minutes Al the speakers cut out...any ideas??? Please help...need tunes. The only thing I can do is pull the radio fuse and everything goes back to normal. FYI when the speakers go out the head unit is still on.
Sounds like the stock amp is going into some kind of protection mode. Try pulling the wires off of the LOC, if the issue goes away you either have it wired wrong or that LOC isn't compatible with the C6 amp.
Speakers cut out
