Sponsored by: DashLynx
LED low bulb not allowing headlight motors to go back down?
Old 08-27-2015, 04:49 PM
Chris Edwards
Chris Edwards's Avatar
Default LED low bulb not allowing headlight motors to go back down?
I installed some LED 9006 bulbs and the lights work fine, but once the headlight doors pop up, they will not go back down when the lights are turned off. I assume I need a resistor of some sort, does anyone have any ideas?
Old 08-28-2015, 10:37 AM
markcz
markcz's Avatar
I remember seeing the fix for that years ago in the C5 sections, you should be able to find it with a search.
Old 08-29-2015, 09:01 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
While a resistor would work, it will also present a substantial fire hazard given how hot it would get. Load resistors for LED turn signals only have to dissipate ~25w of power. A headlight resistors that could compensate for LED bulbs would have to Dissipate over double that wattage.
A much simpler solution is to simply turn on your high beams, then turn off your headlights. As long as you have halogen high beam bulbs this will work.
Old 08-29-2015, 10:33 PM
jdmvette
Night Owl for life
Support Corvetteforum!
jdmvette's Avatar
Received 3,247 Likes on 1,668 Posts
those things cant be very bright...got any pics?
To LED low bulb not allowing headlight motors to go back down?
Quick Reply: LED low bulb not allowing headlight motors to go back down?
