Novak jack aux input gone wrong
I did the Novak jack aux input on my radio a few weeks back and it JD some bleed through of the cd being played. The past few days it ha gotten worse. If I hit a bump it would flip back to the cd being played as the input. Could not take that so I figured I could remove the wires going to CD player and the switch. I assumed this would not allow the CD player output to go through the jack and to the speakers. Wrong. if you hit a bump the CD player takes over and you can tap the CD player and it will go back to the aux input. I don't understand how the CD player audio is getting to the amp since I "thought" I removed the wires left and right signal from the circuit. Would it be possible to wire in just a 2 pin aux input and not have any CD player function at all? This would be great also.
