Sponsored by: DashLynx
Kenwood FM reception issues?
Old 11-11-2015, 03:05 PM
luvchevs
luvchevs's Avatar
Default Kenwood FM reception issues?
Anyone feel the Kenwood FM reception not as good as factory radio?
Anything that can be done to improve this?
Dave
Old 11-11-2015, 11:34 PM
STL_Hokie
STL_Hokie's Avatar
Dave
My reception is significantly better than the factory stereo in my '08.
Old 11-12-2015, 01:14 AM
markcz
markcz's Avatar
Dave
Several threads about this already. Plastic cars just don't make good antennas
Are you still using stock amp/speakers? If yes you're already powering the oem antenna module. If no, connect HU blue/white wire to wire at B3 of oem plug.
If oem module is powered and still bad reception you can try an "FM Signal Amplifier" on ebay for under $10. In my '07 it worked pretty good, but in my '12 it didn't help much.
If that still isn't enough, many have had good results with a Metra 44-UA200 for about $20.
Old 11-18-2015, 09:00 AM
CraigE
Support Corvetteforum!
CraigE's Avatar
Where is the oem (FM) antenna module located ?
What is the best way to confirm that it is powered ?
I have a Kenwood in a 2007 C6 and the FM reception is poor.
Old 11-18-2015, 09:25 AM
markcz
markcz's Avatar
Physical location is on rear wall in trunk.
If you're using oem amp/speakers, it's powered. If aftermarket amp, you need to connect HU amp trigger wire to wire at pin B3 of the main plug.
Old 08-15-2018, 08:25 AM
Formula8
Formula8's Avatar
I am pulling out an older Kenwood head unit with poor reception and installing a new Kenwood which also has poor FM reception. I assume the antenna amplifier is not powered up. I don't have a wiring diagram for my C6Z. Before I go on a fishing expedition in my dash, how do I identify the amp trigger wire at B3 or main plug?
To Kenwood FM reception issues?
Quick Reply: Kenwood FM reception issues?
