Routing cables to rear of C5
I am installing front and backup cameras on my 2002. The typical method people have used for installing the backup camera has involved drilling a hole in the body behind the rear bumper to pass wiring for the camera. However, I am not interested in drilling any holes in the car and instead plan to route the cable for the camera through the bulkhead grommet behind the battery and then run it back to the rear of the car.
Is there anyone else on here that has done the same? what did you use to retain the harness, what route did you follow, etc?
Thanks,
Thanks,
Don't do what exactly?
To the best of my knowledge, there are no OEM grommets at the rear of the car. If there are, can someone shed some light on where?
