Wiring Questions on Aftermarket Pioneer to replace Bose on C6
I have a C6 2005 Corvette WITH Bose and WITHOUT On-Star.
I am wiring up a Single DIN Pioneer DEH-P3600. I plan to order the rp3gm11 from Double D.
The Pioneer has 4 RCA outputs. The Wiring Diagram for Pioneer says 2 RCA jacks are for the “Front Power Amp” and 2 RCA jacks are for “Subwoofer Power Amp”. I want to confirm, do I connect the 4 RCA’s from the rp3gm11 to the 4 RCA’s on the Pioneer?
If so, how do they match up? It looks like the 4 RCA’s from the rp3gm11 are ( WHITE, RED, PURPLE & GREEN ).
I suspect PURPLE & GREEN RCA’s are the rear’s? Do the WHITE and RED the RCA’a plug into the “Subwoofer Power Amp output’s” on the pioneer?
One more question. In my research I see some say to tap the Orange wire from the Pioneer into the AH/TC. Can’t I just connect it to the Orange wire from the Pioneer to the Orange wire on the rp3gm11?
Thanks for any help.
The 2nd set of RCA's on that radio can be selected between sub or non-fading, choose non-fading and connect them to the rear inputs on the RP3. Don't have any HP or LP filters on, leave everything on full pass
Left/Right Front/Rear wire colors are on RP3 instructions.
Wires to connect:
HU red/yellow/black to same on RP3
Same with blue/white, connect HU to RP3
Orange/white on RP3 will not work, connect HU orange/white to gray/black at TC/AH button
Wires to connect:
Wires to connect:
Wires to connect:
