CD player for a C7?
That would be the plan.
It might be wishful thinking the car's entertainment interface system would recognize it, but simply hardwiring it to the speaker/amp setup with a wireless remote would work for me.
Do you see a problem?
It sounds like a lot more work and a lot more expense than sitting at a computer for a couple hours to get 20-30 discs onto a thumb drive which we know your car will recognize, and which definitely won't blow it up.
If you burn the CD's to MP3 at 128k there is no way you'd ever be able to tell the difference between that and direct from CD once it goes through any part of the stock setup.
If you end up using a portable CD player of any type it would definitely be best to connect it to the 3.5mm headphone jack in the armrest cubby. Going straight to the rear speakers would also require an amp of some type, and I can guarantee you that it won't sound near as good as if you played through all speakers via the 3.5 jack. If you use a portable player just adjust the headphone outlet volume to the lowest distortion. If you use a player with an available line-level (RCA) output, it would be best to use that.
But I still say that IN A STOCK C7 AUDIO SYSTEM, 128k MP3's on a usb will sound just as good, if not better, than a portable CD player wired into the headphone input
Last edited by Trios; 05-05-2016 at 05:37 PM. Reason: darnit mark, now you had me using burn instead of rip...
OP, get this below. Mount it into your cubby or near your center console.
The output of this will be connected to your mini aux in. Hardwire power to it.
Includes a remote eye so technically you could mount it anywhere.
Surprised no experts suggested it yet. Pretty simple solution.
http://www.qualitymobilevideo.com/dv...gAJhoCfVXw_wcB
With elevated blood pressure and grinding my teeth I have decided to record a CD to a USB drive as a test.
Using Windows 10 Media Player and having never ripped a CD before, should I choose 192k or 128k?
Thanx...that's what I opted for.
Although I'm not sure exactly how I did it, I managed to copy the CD soundtrack to Batman by Prince.
Sounded decent, but I'm going to compare it to the disk on my Grand Cherokee's system to be sure.
As an excuse to drive the car, I drove to Tualatin for lunch with the Mrs.
She wasn't too happy about having to shout over the tire noise when trying to talk me.
Admittedly, the tire noise from I5 was almost deafening.
I had to turn the music WAY up to help drown it out.
Since no one here in town does it anymore, will be checking into finding someone in the Portland area to do some undercoating.
#33
Eventually you'll have all 5000 albums in your car all at once. How much of a PITA would that be with real CD's
#35
At my age, 417 hours is highly valuable.
I know what I have and can pick it off a shelf in seconds.
Regardless, I've resigned myself to thumbdrives...so it goes in life.
#37
You're going to get a *whole* lot more listening/driving time than time waiting for the discs to rip, especially since you can put the disc in and go do something else for a few.
#38
Not unusual for one disk to last several "trips."
Unfortunately, CDs are downstairs and my computer is upstairs.
I'm at that point in life when stairs become enemies.
#39
I should also say that you're trying to force an audio format created in the 1970's into a 2016 model vehicle. CD audio is literally 37 years old.
The C7 is just the first of a wave of vehicles that won't support your CD collection; you'd really be better served by learning how to use the new (and frankly, much, much better/easier) methods of playing music NOW, instead of trying to force each new car you buy to go back 40 years.
I know your struggle, I've been there and trust me, you'll be kicking yourself for not doing it sooner.
My old 73 mustang mach1back in 1989, I spent a boat load of money on the state of the art Sony pull out CD player and the Sony tape drawer because I just couldn't let the cassettes go. Lol, I was a die hard. Just try it. Thumb drives are stupid cheap and a 32 gb holds a lot of music. Find someone computer savvy and just try it. All the artists and albums and all the endless possibilities.
#40
The easiest solution is to get someone to rip the CD's for him.
On a side note, I'd challenge him to listen to a cd in my truck with all aftermarket equipment, and then through my kenwood with Bluetooth from my iPhone and tell me he can hear a difference. I've been an audiophile for as long as I can remember, I'm 49, and I can't.
There's a aftermarket system in everyone of my vehicles. I'm in Arlington and would drive to him to prove the point.
