My only complaint is the cup holders are too small. They will only hold a can of soda. If you have anything slightly bigger than a can, even a koozie around it, it will not fit. I am thinking about boring these a bit larger if I can find the inner plastic pieces. If anyone knows where I can find some larger ones please respond.
Do you think there be any issues with these working with one of the partisions that a couple of vendors sell?
have no idea as the amp racks are made to fit the amps. All amps are different sizes so you can not have just one universal amp rack. The amp itself is a different size
some have connections on sides(left and right of amp rack) and some have them on front or back so that matters in how I build them
do you have typical dimensions for the amp rack with cup holders?
