New touchscren install questions
So i bought a new in dash nav unit for a forum member here, the unit looks great and i got all the the harnesses and things needed to keep onstar and steering wheel controls, now if i can only get it all hooked up right. does anyone know where i can find a video or info on what plugs into what ? i'm totally lost.
Lots of info in the C6 audio faq thread. This thread has most of what you need, but it does vary a bit depending on which interface adapter you have.
If you got everything used the adapter should already be connected to the HU, which almost makes it plug-n-play, just find the adapter plugs that fit each of the car plugs.
HU orange goes to grey/black under TC/AH button. HU purple is for reverse trigger (if rear camera being installed).
If you have any other stray wires, post a pic or describe them here.
