Sponsored by: DashLynx
Upgrading C6 speakers
Old 07-10-2016, 05:34 PM
vertC6
Support Corvetteforum!
vertC6's Avatar
Default Upgrading C6 speakers
I have a 2013 C6 convertible with Bose speakers and I want to keep my factory head unit but upgrade the door speakers in the speakers behind the seats.
What do you guys recommend for speakers without adding amps or new head unit?
Old 07-10-2016, 10:30 PM
markcz
markcz's Avatar
You're very limited on the improvement you'll get from just replacing the speakers.
For the doors, any 2-way 4ohm 3.5" speaker will help with better highs, but volume will be the same.
IMO, rears aren't really worth it since the Bose amp/processor messes with the sound so much, but again you can drop in a 4ohm 5.25" set without issues.
Call Dennis at DoubleDmods.com to see what he has available
Old 07-10-2016, 11:22 PM
vertC6
vertC6's Avatar
What's your thoughts on the kicker 5.25's for the rears?
Old 07-11-2016, 06:15 AM
markcz
markcz's Avatar
Should sound better than oem
Old 08-05-2016, 01:27 PM
Orion2011
Orion2011's Avatar
I have the non Bose system. I installed Polk Audio DB series speakers in mine. They have a high sensitivity to help squeeze a little more volume out of your factory amp.
Nice improvement over the factory paper speakers.
Old 07-16-2017, 12:08 PM
jonparks
jonparks's Avatar
Speakers in the rear are mono and you will see very little improvement. I replaced all the speakers in my last c6 and kept the head unit. I was very disappointed.
Old 07-19-2017, 11:17 AM
89Roadster
89Roadster's Avatar
Assuming you're going to keep it a while you may as well bite the bullet and put an amp or 2 in if you really want an improvement. I put Infinity Kappas in the back of my vert with an Alpine amp driving them and they sound great.
Old 09-26-2017, 08:38 PM
skar
skar's Avatar
I read that replacing head unit would help .
So I did and it does sound better . Still needs
More bass .
Old 09-26-2017, 10:56 PM
racebum
racebum's Avatar
high efficiency speakers are a must. JL audio c2 is okay. morel maximus is a great one. not to be confused with maximo from the same company
Old 09-27-2017, 08:44 AM
02BlownZ06
02BlownZ06's Avatar
You might want to read this before calling:
https://www.corvetteforum.com/forums...h-dd-mods.html
To Upgrading C6 speakers
Quick Reply: Upgrading C6 speakers
