Door blocking panel for the C6
Guys,
Does anyone make the door blocking panels that you use to cover up the hole in the doors for the C6? Raamaudio doesn't make them anymore.
Thanks!
Daniel Eaton
Thanks!
Daniel Eaton
Traffic wise, 3 days in the audio section is about the same as 3 hours in the general section
If you have tools available it wouldn't be hard to DIY a set out of 1/4" MDF, sheet metal, expanded metal, or any type of lightweight plastic. The divider itself doesn't do much IMO unless you cover it with soundproofing material.
