Sony XAV-AX100 Double Din in C5 without cutting?
The brand new Sony XAV-AX100 with Apple Carplay and Android Auto double din unit has a single din body with only the screen being double din. I want to install a double din in my C5Z, but I dont want to cut the bracing inside and it looks like this may be a solution. I'm hoping somebody with more knowledge would be able to chime in before I make any purchases.
Not quite, I actually found a side picture of it, package actually comes with an adapter cage to turn a double din into a single din lol, also concerned with how this would line up...
Former Vendor
you wont need to cut the bracket with this radio but would want to go double din on bezel for a perfect fitment with no gaps on sides and to keep radio face from hanging down into the hvac area
Even some single din radios require it to be removed (or at least bent) to install them, but it mostly depends on the installation adapter that you get. If your mounting plate centers the radio or has it on the top half, then you shouldn't have to touch the bracket. If mount has radio on bottom half, the bracket has to go.
