New Kenwood DDX9703s Install -- No Sound
Needs some help! I just installed a brand new Kenwood DDX9703s in my 2006 Z06 Corvette and thanks to Dennis, It was a pretty straight forward install, followed his thread to make sure I did everything correct. I even sent him a pic of the wiring and it looked good to him, but I am getting absolutely no sound. Anyone run into a problem like this or have any ideas? Thanks in advanced.
Are the speakers connected directly to the Kenwood or to an amp (stock or aftermarket)? If to an amp, is the amp turning on when the radio is turned on?
You either popped the AMP fuse (31 or 32ish under the hood), you didn't connect the aftermarket radio red wire to the interface, or your interface isn't working properly.
If it's the interface not passing the signal through, you can fix it by connecting the red HU wire directly to the wire lined up to the stock white wire at B3 of the big radio plug (connect it to the interface wire on the car side of the interface).
That did it. Had to take the blue/white wire coming from the HU and splied it into the blue wire between the RG4 and the connector to the car and the sound was amazing. Thanks
