Sponsored by: DashLynx
C6 Z06 Amp Power Wire connection to battery in Hatch
Old 02-20-2017, 11:21 PM
mitco39
mitco39's Avatar
Default C6 Z06 Amp Power Wire connection to battery in Hatch
Hey Guys,
I have looked for a post that showed in detail what a guy did to hook up his amp to a battery that is in the trunk like on the 13 C6 Z06. There is very little room to get to the terminals to add any sort of connection so I am just curious how you guys are doing it? Are you cutting the factory power cable and putting a distribution block in line with it? Or have you found a unique terminal clamp to use?
Thanks so much in advance,
Mitch
Old 02-21-2017, 12:39 AM
markcz
markcz's Avatar
In my '12 GS I used a marine terminal from Wal-Mart (like this) and snipped the stock cables to install spade terminals. You can add whatever you want to once it's installed
Old 02-21-2017, 10:13 AM
mitco39
mitco39's Avatar
That will work! thanks so much! I was struggling trying to find something that would fix in that space.
To C6 Z06 Amp Power Wire connection to battery in Hatch
Quick Reply: C6 Z06 Amp Power Wire connection to battery in Hatch
