double din in a c5?????
has anyone installed a double din radio in a c5? i would like to get a double din radio and was wondering what it would take to make it fit.
thanks in advance.
thanks in advance.
Re: double din in a c5????? (SupraEater)
It can be done. I have a about a dbl din and half in mine. Several guys here do. You will just need to modify the trim bezel
Re: double din in a c5????? (EatRice)
wow...thanks for the pic. guess that answers my question. did you trim the top and the bottom of the bezel?
I cut the bar between the AC and the radio. Then moved the ac to the bottom Then I molded in the AC face and the spot I had to cut to remove the bar.
do you have a replacement carbon fiber dash or just overlay...i am guessing overlay. where did you get that as well? what about the carbon fiber shift boot, steering wheel wrap and e brake boot? you did what i was planning on doing. did you use fiber glass or the horse hair mixture to fill in the spots on the center console??
thanks
[Modified by SupraEater, 6:56 PM 6/25/2004]
thanks
