2006 with ebony interior
I don't believe any one has even done a victory red c6 yet,I think they all are precision red. Maisto does have a red convertible with the ebony interior that could be swapped into a Maisto Red Coupe.
Probably will end up being the solution, I had the same problem with a silver 2001 Z06 that no one ever made with the modified red interior (two tone) so I have to disassemble and paint that interior as well.
If you want a 2005, they have red (precision). I have swapped the interior in the Hotwheels 2005 1:18 from Cashmere to Ebony. In the coupe, it is not that hard to do. I found a White with Ebony and Red with Cashmere took them apart. Just be carefull prying the door panels off. The Silver Hotwheels coupe has the Ebony also.
I have not had a chance to check out the Maitso yet.
