FS: C6 & ZO6 Big Brake Kit Upgrades Brembo, StopTech, Motul, dba, Cooling
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Brembo, StopTech
Chevrolet Corvette C6 Z06 | Grand Sport Front 6-Piston Monoblock | 350x34 mm (13.8") | 2-Piece Discs Slotted Fits Factory Wheels
kit uses the VERY high thermal 34mm thick rotor ring with 72 vanes.
Corvette C5 Front 6-Piston Monoblock | 355x32 mm (14") | 2-Piece Discs Slotted
http://www.xplosiveperformance.com/9...ed_p_3035.html
2006- 2011 Chevrolet Corvette (Z06; GS) - 2pc Rotor Red 6-Piston Rotor: 355 x 32mm
StopTech 97-04 Chevrolet Corvette Front BBK w/ Red ST-60 Calipers Slotted 355x32mm Rotors
http://www.xplosiveperformance.com/S...s-_p_3183.html
Chevrolet Corvette C6-Piston Monoblock | 355x32 mm (14") | 2-Piece Discs Slotted
http://www.xplosiveperformance.com/C...ed_p_3331.html
05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
XP Motorsports 05-13 Corvette C6/ZO6/ZR1 Front Grille Mounted Brake Cooling Duct System
Everything you need to install grille mounted brake cooling in your C6 Corvette. The ducts fit behind the front grille no need to loose your fog lights. The ducts mount on the inner grille support (triming of the support is required). For ease of installation removal of the front bumper is required.
Kit Includes
(2) Large Brake Duct Vents
(2) Spindle Mount Brake Hose Adapters
(2) 3" Hose Clamps
(10Ft) High Temperature 550 degree Silicon Brake Hose
(1) Horn relocation Bracket
Mounting Screws
Instructions
(2) 3" Hose Clamps
Mounting Screws
Instructions
Chevrolet Corvette C6 Z06 | Grand Sport Front 6-Piston Monoblock | 365x34 mm (14.4") | 2 Piece Discs Slotted
Chevrolet Corvette C6 Z06 | Grand Sport Front 6-Piston Monoblock | 380x32 mm (15") | 2-Piece Discs Slotted Rotors
2006-2013 Corvette ZO6 SS Brake Line Kit Goodridge set (4) w/Motul RBF 600 (3) Bottles
$184.25
ZO6
http://www.xplosiveperformance.com/2...es_p_3492.html
C6
http://www.xplosiveperformance.com/2...s-_p_3493.html
C6
2006-2013 Corvette ZO6 Phantom G-Stop Brake Lines Goodridge set (4) w/Motul RBF 600 (3) Bottles
$231.25
ZO6
http://www.xplosiveperformance.com/2...s-_p_3495.html
C6
http://www.xplosiveperformance.com/2...s-_p_3494.html
ZO6
C6
See all our Brake Maintenance Products
http://www.xplosiveperformance.com/M...ce_c_6573.html
Rotors
http://www.xplosiveperformance.com/Rotors_c_6574.html
PADS
http://www.xplosiveperformance.com/B...ds_c_6572.html
Rotors
PADS
Former Vendor
St. Jude Donor '13
Brembo, StopTech
http://www.xplosiveperformance.com/C...ls_p_2987.html97-04
http://www.xplosiveperformance.com/2...m-_p_3165.html
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Chevrolet Corvette C6 05-13 6-Piston Monoblock | 365x34 mm (14.4") | 2 Piece Discs Front
http://www.xplosiveperformance.com/C...t-_p_3353.html
http://www.xplosiveperformance.com/C...ed_p_2985.html
http://www.xplosiveperformance.com/C...rs_p_2984.html
97-04 Corvette C5 Front Slotted 4000 Series Rotor Right & Left Pair w/Hawk DTC70 Pads
1997-2004 Corvette C5 Stop Tech Gas Slotted Front & Rear Rotors w/Hawk HP Plus Brake pads
Package Includes
(1) Right Front Gas Slotted Rotor
(1) Left Front Gas Slotted Rotor
(1) Right Rear Gas Slotted Rotor
(1) Left Rear Gas Slotted Rotor
(1) Set Front Brake Pads (4 pieces)
(1) Set Rear Brake Pads (4 pieces
$593.97 delivered lower US
http://www.xplosiveperformance.com/1...ds_p_2901.html
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
$575.95 delivered lower US
http://www.xplosiveperformance.com/9...ds_p_3524.html
Package Includes
97-04 Corvette C5 ZO6 HPDE Starter Track Pack Brake Package (1) Set (4 Lines) Goodridge Corvette C5 Stainless Steel Brake Line Kit
Motul RBF600 Case of 12
Motul RBF660 racing DOT4
Motul RBF660 racing DOT4 (Case of 12)
(1) Set Hawk HP Plus Street Front Brake Pads 1 pcs design
(3) Pints Motul RB600 High Temp Race Brake Fluid
(2) StopTech Front Gas Drilled Rotors
$564.35 delivered lower US
http://www.xplosiveperformance.com/9...e-_p_3500.html
Motul RBF600 is the best high-temperature Brake Fluid and preferred by many tuners and race teams. Its specifications and labratory results exceed that of DOT 5 silcone based fluid, but still retains the benefits of Glycol based fluid by lubricating the ABS pump and not deteriorating caliper and Master cylinder seals
100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. Each bottle is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point 594F(312C) helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 401F(205C).
500ml bottles
1.05 pint
$17.95 each
http://www.xplosiveperformance.com/M...00-_p_648.html
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Package Includes
500ml bottles
1.05 pint
$17.95 each
500ml bottles
1.05 pint
$17.95 each
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
(2) 3" Hose Clamps
Mounting Screws
Instructions
Corvette C6 & ZO6 Street/Track Packages
Corvette Z06 Package 2005-2012 Rotor Slotted Left/Right Front Set
Take full advantage of your stoppers with these DBA Club Spec 4000 T3 brake rotors. These rotors are full of features desired by the track enthusiast and weekend cruiser alike. DBA's exclusive XG150 high-carbon alloyed iron and TSP process allows these rotors to withstand extreme heat without the serious degradation found in other, lesser rotors. DBA's patented Kangaroo Paw ventilation provides awesome heat dissipation, and their T3 slot design dampens vibration for quiet, responsive braking and pedal feel. To keep these rotors looking as great as they perform, DBA applies a protective paint onto the non-friction areas, along with heat paint marks, so you can monitor peak breaking temperatures. Reign in all of that speed safely with these DBA Club Spec 4000 T3 brake rotors.
Patented ‘Kangaroo Paw’ ventilation design* provides greater heat dissipation
Tri-Symmetrical T3 Slot design dampens the vibration harmonics resulting in a quieter, responsive and a further improvement of brake pedal feel when compared to the T2 slot design
XG150 High Carbon Alloyed Iron increases the thermal capacity properties of the rotor
TSP (Thermal Stability Profiling) prolongs the service life of the rotor. This process is only applied to HEAVY DUTY, T3 4X4 and CLUBSPEC rotors containing XG-150 high carbon alloyed iron
Protection paint on hub and non friction surfaces
Heat paint markings change colour to monitor peak braking temperatures
http://www.xplosiveperformance.com/C...et_p_2406.html
Front Package
Kit includes (2) Rotors
Front Right
Front Left
$391.68
Free Shipping Lower USA
Corvette C6 - Z06 Package 2005-2012 Rotor Slotted Left/Right Rear Set
http://www.xplosiveperformance.com/C...s-_p_2407.html
Rear Package
Rear Right
Rear Left
$391.68
Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk Ceramic Pads
http://www.xplosiveperformance.com/C...ds_p_2441.html
$584.68
Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Front Set w/Hawk HP Plus brake pads
http://www.xplosiveperformance.com/C...ds_p_2438.html
$624.68
Corvette C6 - Z06 Package .2005-2012 Rotor Slotted Left/Right Rear Set w/Hawk Ceramic Pads
http://www.xplosiveperformance.com/C...ds_p_2440.html
$541.68
Corvette Z06 Package 2006-2012 Rotor Slotted Front & Rear Set T3 Design Hawk HP Plus
Package Includes:
(2) Front T3 Club Spec Slotted 4000 Series Rotors
(2) Rear T3 Club Spec Slotted 4000 Series Rotors
(1) Set Hawk HP Plus One Piece Front Pads
(1) Set Hawk HP Plus One Piece Rear Pads
http://www.xplosiveperformance.com/C...ds_p_3402.html
$1,096.25
Corvette Z06 Package .2006-2012 Rotor Slotted Series 4000 Front & Rear Set T3 Design Hawk DTC70/DTC60 Front & Rear Pads
Package Includes:
(1) Set Hawk DTC70 One Piece Front Pads
(1) Set Hawk DTC60 One Piece Rear Pads
$1196.25
Shipped lower us
http://www.xplosiveperformance.com/C...ds_p_3506.html
PADS ONLY
2005-12 Z06 & GS Hawk HP Plus Pads -Front- New 1 piece pads (4/set)
http://www.xplosiveperformance.com/2...t-_p_2433.html
$215.50
2005-12 Z06 & GS Hawk DTC-70 Race Pads -Front- New 1 piece pads (4/set)
http://www.xplosiveperformance.com/2...t-_p_2565.html
$299.99
2005-12 Z06 & GS Hawk Ceramic Pads - Front - New 1 piece pads (4/set)
$193.00
http://www.xplosiveperformance.com/2...et_p_2430.html
2005-12 Z06 & GS Hawk Ceramic Pads - Rear - New 1 piece pads (4/set)
$147.98
http://www.xplosiveperformance.com/2...t-_p_2431.html
06-12 Corvette Z06 HPS Street Front Brake Pads 1 pcs (4/set) $187.00
http://www.xplosiveperformance.com/0...et_p_3146.html
06-12 Corvette Z06 HPS Street Rear Brake Pads 1 pcs (4/set) $159.38
http://www.xplosiveperformance.com/0...et_p_3147.html
2006-12 Z06 & GS Hawk DTC-60 Race Pads -Rear- New 1 piece pads (4/set)
$256.60
http://www.xplosiveperformance.com/2...t-_p_2614.html
C6/ZO6 Slotted Rotors & Hawk Brake Pad Packages
06-12 Corvette Z06 Street Package (4) StopTech Rotors Hawk Ceramic Front & Rear 1 piece pads
Package Contains:
(1) StopTech Gas Slotted Front Left one piece Rotor
(1) StopTech Gas Slotted Front Right one piece Rotor
(1) StopTech Gas Slotted Rear Left one piece Rotor
(1) StopTech Gas Slotted Rear Right one piece Rotor
(1) Set Hawk Ceramic Front 1 piece brake pads
(1) Set Hawk Ceramic Rear 1 piece brake pads
http://www.xplosiveperformance.com/0...ds_p_3191.html
$707.10 delivered Lower US
06-12 Corvette Z06 Street Package (4) StopTech Rotors Hawk HPS Pads Front & Rear 1 piece pads
Package Contains:
(1) Set Hawk High Performance Street (HPS) Front 1 piece brake pads
(1) Set Hawk High Performance Street (HPS) Rear 1 piece brake pads
http://www.xplosiveperformance.com/0...s-_p_3192.html
06-12 Corvette Z06 Street/HPDE Track Package (4) StopTech Rotors Hawk HP Plus Pads Front & Rear 1 piece pads
Package Contains:
(1) Set Hawk HP Plus Front 1 piece brake pads
(1) Set Hawk HP Plus Rear 1 piece brake pads
http://www.xplosiveperformance.com/0...s-_p_3193.html
$756.95 delivered Lower US
06-12 Corvette Z06 HPDE & Race Track Package (4) StopTech Rotors Hawk DTC 70/60 Front & Rear 1 piece pads
Package Contains:
(1) Set Hawk DTC 70 Front 1 piece brake pads
(1) Set Hawk DTC 60 Rear 1 piece brake pads
http://www.xplosiveperformance.com/0...s-_p_3194.html
$959.95 delivered Lower US
05-12 Corvette C6 Base Street Package (4) StopTech Rotors Hawk Ceramic Front & Rear Pads
Package Contains:
http://www.xplosiveperformance.com/0...s-_p_3196.html
$589.10 delivered Lower US
05-12 Corvette C6 Street Package (4) StopTech Rotors Hawk HPS Pads Front & Rear Pads
Package Contains:
http://www.xplosiveperformance.com/0...el_p_3197.html
05-12 Corvette C6 Street/HPDE Track Package (4) StopTech Rotors Hawk HP Plus Pads Front & Rear Pads
Package Contains:
http://www.xplosiveperformance.com/0...ds_p_3198.html
$634.10 delivered Lower US
05-12 Corvette C6 Base HPDE & Race Track Package (4) StopTech Rotors Hawk DTC 70/60 Front & Rear Pads
Package Contains:
http://www.xplosiveperformance.com/0...s-_p_3195.html
$827.75 delivered Lower US
$184.25
ZO6
C6
$231.25
ZO6
C6
06-13 Corvette ZO6 HPDE Starter Track Pack Brake Package
Package Includes
(1) Set (4 Lines) Goodridge Corvette C6/ZO6 Stainless Steel Brake Line Kit
(2) StopTech Front Gas Slotted Rotors
$697.35
http://www.xplosiveperformance.com/0...e-_p_3498.html
06-12 Corvette ZO6 Track Pack Stage II Brake Package
Package Includes
(1) Set Stop Tech Corvette C6/ZO6 Stainless Steel Rear Brake Line Kit
(1) Set Stop Tech Corvette C6/ZO6/GS Stainless Steel Front Brake Line Kit
(1) Set Hawk HP Plus Street Rear Brake Pads 1 pcs design
(4) Pints Motul RB600 High Temp Race Brake Fluid
(2) StopTech Rear Gas Slotted Rotors
$955.55
http://www.xplosiveperformance.com/0...ge_p_3171.html
Rotors
PADS
Follow US on Facebook for additional Specials
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Former Vendor
St. Jude Donor '13
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Brembo, StopTech
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
Front Package
Front Right
Front Left
$391.68
Rear Package
Rear Right
Rear Left
$391.68
$584.68
$624.68
$541.68
Package Includes:
$1,096.25
Package Includes:
$1196.25
Shipped lower us
PADS ONLY
$215.50
$299.99
$193.00
$147.98
$256.60
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
Package Contains:
$184.25
ZO6
C6
$231.25
ZO6
C6
Package Includes
$697.35
Package Includes
$955.55
Rotors
PADS
