View Poll Results: Do you like the Black Friday Deals?
Yes
1
50.00%
No
1
50.00%
I want to see something else on here! (PM us!)
0
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
FS: Black Friday -> Cyber Monday Brake Deals (DBA/Cobalt Friction/Carbotech/PFC/StopTech)
Former Vendor
Black Friday/Cyber Monday Brake Deals (Cobalt Friction/Carbotech/PFC/StopTech BBK)
**We will edit this often with Pictures and updates!**
Speed Freaks LLC is happy to announce their CF Black Friday Sale that ends on Cyber Monday. This sale is put together based on input from CF members in multiple regions and the intro based on input and requests from CF members.
BBK Specials
Combine a StopTech BBK with a Pad Choice (Carbotech, Cobalt, Performance Friction) and get Instant Bundle Savings! PM us with your bundle request for exact pricing!
Options include:
C5 355x32 w/ ST40 [Black or Red Calipers] [Slotted/Drilled/Zinc Slotted/Zinc Drilled] (List $2895-$2995)
-Save $600 when combined with your choice of pads!
C5 355x32 w/ ST60 [Black, Silver, Red, or Yellow Calipers] [Slotted/Drilled/Zinc Slotted/Zinc Drilled] (List $3295-$3395)
-Save $700 when combined with your choice of pads!
C6 355x32 w/ ST40 [Black, Silver or Red Calipers] [Slotted/Drilled/Zinc Slotted/Zinc Drilled] (List $2895-$2995)
C6 355x32 w/ ST60 [Black, Silver, Red, or Yellow Calipers][Slotted/Drilled/Zinc Slotted/Zinc Drilled] (List $3295-$3395)
C6 380x32 w/ ST60 [Black, Silver, Red, or Yellow Calipers][Slotted/Drilled/Zinc Slotted/Zinc Drilled] (List $3595-$3695)
C6 Z06 380x32 w/ ST60 [Black or Red][Slotted/Drilled/Zinc Slotted/Zinc Drilled] (List $3595-$3695)
C6 Z06 380x35 w/ ST60 [Black or Red][Slotted/Zinc Slotted] (List $3695-$3795)
-Save $750 when combined with your choice of pads!
Rotor Specials
DBA Specials to be announced at a later date!
Combine with Pads and get an Instant $100 back (off MSRP) w/ Free Shipping in the Continental US! (Adjustments made after order is placed)
Front Rotor Pair: Girodisc A1-096 Chevrolet Corvette C5 / C6 2pc Front Floating Rotors
Rear Rotor Pair: Girodisc A2-096 Chevrolet Corvette C5 / C6 2pc Rear Floating Rotors
Combine with Pads and get an Instant $125 back (off MSRP) w/ Free Shipping in the Continental US! (Adjustments made after order is placed)
1997-2004 Front
2005-2007 Front (including Z51 Package)
2008-2012 Base Front
Left Rotor: Performance Friction 2 Piece Floating Front Left Direct Drive Rotor 323.045.87 Chevrolet Corvette C5/C6
Right Rotor: Performance Friction 2 Piece Floating Front Right Direct Drive Rotor 323.045.88 Chevrolet Corvette C5/C6
Brake Pad Specials
20% off Cobalt Friction w/ Free Shipping (in continental US)! (Use coupon code: BFCOBALT at checkout)
1997-2004 Front
Cobalt Friction CRB-XR1-D731-15.3MM
Cobalt Friction CRB-XR2-D731-15.3MM
Cobalt Friction CRB-XR3-D731-15.3MM
Cobalt Friction CRB-XR4-D731-15.3MM
Cobalt Friction CRB-XR5-D731-15.3MM
1997-2004 Rear
2005-2007 Rear (including Z51 Package)
2008-2011 Base Rear
Cobalt Friction CRB-XR1-D732-17.0MM
Cobalt Friction CRB-XR2-D732-17.0MM
Cobalt Friction CRB-XR3-D732-17.0MM
Cobalt Friction CRB-XR4-D732-17.0MM
Cobalt Friction CRB-XR5-D732-17.0MM
2010-2011 Grand Sport Front
2006-2011 Z06 Front
Cobalt Friction CRB-XR1-GM1-15.3MM
Cobalt Friction CRB-XR2-GM1-15.3MM
Cobalt Friction CRB-XR3-GM1-15.3MM
Cobalt Friction CRB-XR4-GM1-15.3MM
Cobalt Friction CRB-XR5-GM1-15.3MM
2010-2011 Grand Sport Rear
2006-2011 Z06 Rear
Cobalt Friction CRB-XR1-GM2-15.3MM
Cobalt Friction CRB-XR2-GM2-15.3MM
Cobalt Friction CRB-XR3-GM2-15.3MM
Cobalt Friction CRB-XR4-GM2-15.3MM
Cobalt Friction CRB-XR5-GM2-15.3MM
Free Shipping (in continental US), Combine with BBK/Rotor purchase or PM for pricing!
Quick Compound Ref. Guide for Newbies: (You can jump up and down the pad compounds within Carbotech's offering without worry of rotor transfer layer compatibility).
1521 - Street Compound, the transfer layer is compatible with any of the race compounds. (OK to use on the same rotor as XP/RP compounds).
AX6 - Autocross Compound, has some noise - high torque and low temp threshold. Although used on street, not recommended by manf.
XP8 - Entry level track pad, usually for lighter cars but can be matched with higher ability drivers that don't over use the brake pedal. Commonly used on rears. If used on street, you will see dust and hear some noise. Not recommended for street use.
XP10 - Mid level track pad, higher temp range and bite than XP8. Usually upper limit for use in rear on most cars depending on tire compound and contact patch type/size. If used on street, you will see dust and hear some noise. Not recommended for street use, especially not in colder areas.
Anything higher, please PM us with questions.
1997-2004 Front
Carbotech Performance Brakes, CT731-1521
Carbotech Performance Brakes, CT731-AX6
Carbotech Performance Brakes, CT731-XP8
Carbotech Performance Brakes, CT731-XP10
Carbotech Performance Brakes, CT731-XP12
Carbotech Performance Brakes, CT731-XP24
Carbotech Performance Brakes, CT731-RP2
1997-2004 Rear
2008-2011 Base Rear
Carbotech Performance Brakes, CT732-1521
Carbotech Performance Brakes, CT732-AX6
Carbotech Performance Brakes, CT732-XP8
Carbotech Performance Brakes, CT732-XP10
Carbotech Performance Brakes, CT732-XP12
Carbotech Performance Brakes, CT732-XP24
Corvette C6 - Grand Sport & Z06 Front (Single piece backing plate, replaces padlets)
Carbotech Performance Brakes, CT1185-S-1521
Carbotech Performance Brakes, CT1185-S-AX6
Carbotech Performance Brakes, CT1185-S-XP8
Carbotech Performance Brakes, CT1185-S-XP10
Carbotech Performance Brakes, CT1185-S-XP12
Carbotech Performance Brakes, CT1185-S-XP24
Corvette C6 - Grand Sport & Z06 Rear (Single piece backing plate, replaces padlets)
Carbotech Performance Brakes, CT1185R-S-1521
Carbotech Performance Brakes, CT1185R-S-AX6
Carbotech Performance Brakes, CT1185R-S-XP8
Carbotech Performance Brakes, CT1185R-S-XP10
Carbotech Performance Brakes, CT1185R-S-XP12
Carbotech Performance Brakes, CT1185R-S-XP24
20% off Performance Friction Pads w/ Free Shipping (in continental US)! (Use coupon code: BFPFC at checkout)
1997-2004 Front
Performance Friction 11 Compound 0731.11.15.44 Corvette Front
1997-2004 Rear
2008-2011 Base Rear
Performance Friction 11 Compound 0732.11.17.44 Corvette Rear
Shipping may be delayed from our normal schedule due to holidays. If you have any questions, please feel free to post or PM us!
BBK Specials
Options include:
Rotor Specials
1997-2004 Front
Brake Pad Specials
1997-2004 Front
1997-2004 Rear
2008-2011 Base Rear
2006-2011 Z06 Front
2006-2011 Z06 Rear
1997-2004 Front
1997-2004 Rear
2008-2011 Base Rear
1997-2004 Front
1997-2004 Rear
2008-2011 Base Rear
Former Vendor
PMs Replied!
We are sure this is the most comprehensive listing and choice of pads available for the C5-C6 Platforms. Take advantage of this sale while it lasts!
Former Vendor
Good question via PM from a member - In regards to Carbotech, we abide by the MAP policy in place with the manufacturer and the links display retail pricing w/ free shipping for the fall promotion.
For the Forum Discount and Free Shipping combo to CF members ONLY, you will need to use Coupon Code "CorvetteClub10" at checkout with Carbotech products.
Please feel free to ask any technical questions via PM or posts as well.
