FS: 18" CCW C14 Rims
Sold!! 18" CCW C14 Rims
Sold, thank you corvetteforum!
Selling a great set of 4 CCW C14 rims. Ultimate track wheels, amazing condition, no curb rash what so ever. Size and offset were designed for a base C6. They do fit z06/gs with the addition of wheel spacers to bring the rim flush with the widebody arches due to larger offset. Finish is a CCW factory applied black powder coat (pictures show some dust from sitting in storage). Had a set of NT01 mounted on them, very gently installed and removed.
18x10 +57mm and 18x11.5 +64mm
Thank you.
Thank you.
Asked a buddy of mine and his CCW rubbed a tiny bit when running the 315 tire and slammed.
If you call up CCW and tell them the specs i have listed they will let you know if they will work. Running a narrower 305 is another option.
I just spoke to CCW, they would need to know the invoice number to pull up the exact specs on the wheels as they are all custom. Even with a given offset the mounting pad dimensions can vary, you would not happen to have that info? Also where are you, to est shipping costs
I have more data....measuring using this method:
Fronts-
Overall wheel width: 11"
Wheel width: 10"
Backspace: 7.75"
Frontspace: 3.25"
Offset: +57mm
Rears-
Overall wheel width: 12.5"
Wheel width: 11.5"
Backspace: 8.75"
Frontspace: 3.75"
Offset: +64mm
These rims are designed for a base C6 to run flush with the edge of the fenders bringing them out 0.75" (front) and 1.35" (rear) than stock rims. On a C6Z, these will sit 0.42" (front) 0.43" (rear) more inward than stock z rims.
They are boxed and ready to be shipped!
Thank you.
Fronts-
Wheel width: 10"
Backspace: 7.75"
Frontspace: 3.25"
Offset: +57mm
Rears-
Wheel width: 11.5"
Backspace: 8.75"
Frontspace: 3.75"
Offset: +64mm
Thank you.
