FS: 2003 Z06 Track Car
SOLD 2003 Z06 Track Car
I am selling me 2003 C5 Z06. I bought it 4 years ago and it has 23K on it. I have ran 6 Fast Fridays and 18 HPDE's over the 4 years It has 27,xxx miles. After every event I changed the oil, oil filter, clutch, and brake fluid. The differential and transmission got changed once a year. I have taken out the A/C and radio. The paint on the car is ok for what I have been doing, I added 3M film to nose and hood, rockers, and behind the rear wheels. The rockers have taken a beating and you will see in the pictures that I screwed up and started to winch it up from front tow hook, it pinch the nose and messed up the paint. Also, in the pictures, it is up on my lift, so the tires which are factory comp gray are in my basement. They are in what I would call track shape. I run squared so the are all 18x10.5. Now, the mods:
Throttle blip; NRG steering wheel; front and rear tow hooks, Pfadt gen one coil overs and sway bars installed by original owner, Pfadt bushings; AP 4 piston front brakes; SS lines, 6 point cage welded to the frame; 3 point fire suppression; GM external oil cooler; GM tranny cooler; Ron Davis radiator with oil cooler; Borla cat-back straight pipes; Sabelt driver and passenger seat, Sabelt 5 point harnesses (2 years left). The engine is stock except the K&N air cleaner and a catch can. I run all weekend and there is barely 1/8 of inch of oil in when I am done.
I don't think I left anything out. I am asking $27,000.
