Those running a square setup..
St. Jude Donor '07
I'm trying out a square setup for the first time, with the 305-30-18 GAC scuffs. I had it out tonight bedding the brakes and the car feels *awfully* squirelly under braking. Any difference in alignment/ride height for a square setup vs staggered?
When I was running Toyo RA-1 275s on all 4 corners the car was slightly loose, but nothing I'd call "squirrely". I didn't change anything with my alignment, which is just a bit more aggressive than stock.
Of course, it could be completely different for your C6.
HTH, and have a good one,
Mike
Mike
Do you run any toe-out?
Frank Gonzalez
St. Jude Donor '07
Originally Posted by gonzalezfj
When I run my C5Z with 17-305 front and rear (the T-1 setup) we drop the front about 1/2" to restore the correct rake (front lower than rear). This restores the car's downforce at high speeds and makes it stable.
Frank Gonzalez
Frank Gonzalez
By "squirrely under braking" do you mean that the back end keeps trying to slide, or is the front end getting a bit darty on you? If the front end is getting busy under hard braking, it could make the back end feel like it's trying to come around on you.
Assuming you're bedding in your brakes on normal streets, I could easily imagine the fronts hunting quite a bit with your setup under braking.
Mike
Mike
What kind of pads front and rear? I experienced this when running Wilwood H pads up front and E's in the rear. Switched to H's all around and the problem went away.
St. Jude Donor '07
Matt, I run the square setup (315's all around) on mine. I notice it if I get real, real hard on the brakes, like at T.1 at VIR, when I really need all I can get, the azz end gets a little happy, but not dangerously so. I think it's more to do with the front end getting all the weight transfer and the bigger footprint getting more traction. It's not that big of a deal, but I know it's occuring, and it's very manageable.
I use the Wilwood H's, BTW.
St. Jude Donor '07
St. Jude Donor '07
The car was set up with an RCH of rear toe in, if the brake pad thing doesn't pan out I'll get it re-checked..
Thanks all!
*Edit-DUH, if I changed the ride height that will definitely affect toe-right? Will have it checked tommorrow...
Thanks all!
Don't think small ride height change will affect toe drastically. I think I have 1/16 out in front and 1/8 in on rear.
Thanks all!
Thanks all!
Also, the first few brake applications with unbedded pads can make the car feel squirrelly because you can get different friction right/left as the pads are being bedded to the rotors. This is specially true when the rotors are used.
I'd get some toe-in on the rear and I bet your squirrellyness (man, what a word, eh?) will go away. Best of luck,
Frank Gonzalez
St. Jude Donor '07
Well I just got it corner weighed and aligned, still likes to wander around under braking, it is a little better though. It does seem to be more at low speed (can't really practice a 145 to 65 on the street )
Oh well, we'll see come Saturday-especially if it rains!!
