New product from Hardbar (alignment tool)
Old 07-31-2006, 03:34 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Default New product from Hardbar (alignment tool)
We are now taking orders on this new very useful tool that allows you to do your alignments at home, shop or track. As will be detailed in the instructions that are being finished (they take longer than the product!), you use this tool with the car up on jack stands with the car supported on the a-arms out at the ball joints so that it is very near ride height. With the wheels off you have very easy access to the tie rods and jam nuts. With this tool you need two tape measures and since it hangs lower than the car the tapes have clear shot to the other side where the thumb screws hold the tape ends for one person toe checking and adjustments. I use the Starrett Digi-tape with LCD digital readouts and get it done fast (not shown). If you add a $30 laser (from Home Depot, etc) and a plumb bob you can do thrust angle very accurately so the wheels are pointed down the center of the car. And if you already have a digital camber gauge, put it on the angle piece and rotate lock to lock and get caster.
The tool breaks down in seconds and fits in a 24 inch box in your trailer and is over-designed for years of abuse and still be true. I know there will be many questions and that is why I am still writing the instruction sheet. It is so nice to be at the track and be able quickly to play with a little toe out in the front for quick turn in, or toe in at the rear for better drive out of the corners and immediately see the result. Get you car's setup perfect at the track days, and save in tire wear and buy yourself a second or 2 per lap. I know it sounds complicated but it is very easy and fast.
The tool will retail initially at $199 so it will pay for itself in one use for most of you that take your car to a shop for track days.
Gary Hoffman
Hardbarusa.com
603-682-8073
Old 07-31-2006, 03:40 PM
96LT1
96LT1's Avatar
When do you expect to start shipping them?
Old 07-31-2006, 03:43 PM
ghoffman
ghoffman's Avatar
2 weeks or less. Oh yea, it fits, C4-C6 and any other car with 5 studs on a 4.5 inch circle (Mustangs, etc). Anyone know the C2-3 bolt pattern?
Old 07-31-2006, 06:12 PM
Olitho
Olitho's Avatar
Very cool Gary!
I will take one. There is nothing that gets me more ticked off than trying to do toe-adjustments by myself with the car on the ground.
Putting it up on jacks, wheels off and with a tool like this will make it a pleasure.
How do I order?
Olitho
Old 07-31-2006, 06:32 PM
ghoffman
ghoffman's Avatar
Thanks! When I get a couple more orders I'll pull the trigger on this product.
Old 07-31-2006, 07:10 PM
2SLOW
2SLOW's Avatar
I'll take one!!
Thanx,
Chuck
Old 07-31-2006, 07:37 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Nice, more accurate than toe plates off bend rims and bulging tires.
Old 07-31-2006, 07:50 PM
FastZR1
FastZR1's Avatar
I'll take one too.
(I hope my wife doesn't see this post.)
Old 07-31-2006, 07:51 PM
ghoffman
ghoffman's Avatar
Thanks, faster and alot easier too!
Old 07-31-2006, 07:59 PM
Sidney004
Sidney004's Avatar
I will take one.
Old 07-31-2006, 09:17 PM
Carolina C4 Racer
Carolina C4 Racer's Avatar
I don't know about the C2's but the C3's have the same bolt pattern(4.5) as the C4,5,& 6.
Anthony
96LT1
96LT1's Avatar
2 weeks or less.
I'll take one as well then.
Old 08-01-2006, 06:31 AM
ghoffman
ghoffman's Avatar
Anthony
Thanks! I will tell the shop to start making them, and I will get busy with the Nikon and PC and finish the instructions.
Thanks again!
Old 08-01-2006, 08:57 AM
Gordy M
Gordy M's Avatar
I believe the C1-3 have 4 3/4 spacing and the C4-6 the metric equivalent spacing. Ford and Chrysler often use the 4 1/2 spacing.
Old 08-01-2006, 09:16 AM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Gary
Sign me up for a tool - PM sent.
Thanks,
Bob
Old 08-01-2006, 10:40 AM
Sean@OCCorvette
Sean@OCCorvette's Avatar
I'll take one.
Old 08-01-2006, 04:33 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I'll be ordering one of these soon as well.
To New product from Hardbar (alignment tool)
Old 08-01-2006, 04:48 PM
ghoffman
ghoffman's Avatar
Thanks everybody, wow!!! The stock has been ordered! The machine shop and anodizers' are happy as well!
Old 08-01-2006, 05:16 PM
XGRANDSPORTX
XGRANDSPORTX's Avatar
Put me on the list I will take one as well
Alan
Old 08-02-2006, 06:54 AM
Scooter70
Scooter70's Avatar
This is a great looking product Gary. All Corvettes 1963 and up are 5x4.75". The earlier cars may be the same but I wasn't able to find out how far back.
http://www.discountedwheelwarehouse...._Reference.cfm
http://www.ronalusa.com/cars.html
Quick Reply: New product from Hardbar (alignment tool)
