Video Cam Mount Information Needed
Old 08-27-2006, 08:22 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Default Video Cam Mount Information Needed
I have just purchased a new Sony DVD cam corder and want to take on track videos. The problem is how to mount the camera to the roll bar in the car. I have the RD 4 point bar which has a cross tube that would be an ideal centered spot for attaching the camera and mount. What is everyone using for a mounting bracket? I would like something that has the universal screw mount to use with the tripod mounting location on the bottom of the camera. Info and links would be appreciated.
Old 08-27-2006, 09:26 AM
c4cruiser
c4cruiser's Avatar
Check out these mounting brackets by ChaseCam: http://www.chasecam.com/
They have a bar clamp that appears to fit the R-D Racing bar (the R-D bar is 1.5" wide) and the suction cup mounts look to be very strong if you want a window mount.
Old 08-27-2006, 10:52 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Good luck with the Sony DVD Sony mine won't run in the car more tahn a minute or two then it shuts off. I continue to use my old one which is a tape. IO Port is a good mount not sure if it will work in your case with the cross bar.
Old 08-27-2006, 11:18 AM
tchapma1
tchapma1's Avatar
Don't know what diameter the bar is or anything, but I am using this on a BK harness bar.
http://www99.shopping.com/xPF-Bogen-...amp-Tube-Mount
I got turned on to it by an SCCA forum where someone recommended one. I bought two of them on ebay, so I've got a spare I would sell if you're interested. PM me if you are.
Old 08-27-2006, 11:52 AM
01Pewter
01Pewter's Avatar
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
I am using the "I/O Port Video Camera Mount".
It comes in 1" for harness guide bars, and 1¼" to 2" for roll bars and cages. The mount features a special polyurethane bushing to help eliminate the high-frequency vibrations.
I also use the Bogen / Manfrotto 3299 RC2 System Quick Release Adapter with 3157N Plate for easy mounting of the camera to the mount.
Old 08-27-2006, 05:30 PM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I use it in my 97' for road racing and drag racing......works great.
here is a pic
Old 08-28-2006, 05:23 PM
chanderson
chanderson's Avatar
Originally Posted by chanderson
Just for those of you interested in an in-car camera setup. I found some suppliers of mounts and camera supplies and made my own. I found that the mount is extremely steady and would hold up to drag racing or road racing applications. Almost limitless possiblities in camera angles.
http://s73.photobucket.com/albums/i2...IncarEdit2.flv
http://s73.photobucket.com/albums/i2...IncarEdit1.flv
hope this works
Old 08-28-2006, 05:59 PM
Joseesp
Joseesp's Avatar
I'm also using the SONY DVD video camera with IO port which shut off after a few minutes. As per recommendations found on this forum, I further insulated the mount to the harness bar with a rubber sheet. It is now working perfectly.
Old 08-28-2006, 08:25 PM
CHJ In Virginia
Thanks for all the input guys.. I appreciate the help.
To Video Cam Mount Information Needed
Quick Reply: Video Cam Mount Information Needed
