Oil coming out dipstick
Guess I have a blowby problem. I noticed it at an autox this w/e, so thought you guys that race like this may have better experience. Lots of oil spraying out the dipstick. What does this mean?
1-Possible PCV blocked
2-Engine on it s way out, blow by past the rings causing pressure in the crank case forcing oil out the easiest way, the dip stick.
Temp way to deal with it, buy an oil cap, drill a hole in the center of it, Insert a small pipe & epoxy the pipe into it. Run a rubber line from the dip stick tube to the new pipe in the oil cap, clamp it. I did this for 3 races on my 1989 L98 to get me through to the end of the season. When I disassembled my engine the rings came out in pieces.
The engine will be down on power because it is done, but this will get you through the next few events if you are trying to finish out a season.
Besides the hose between the d-stick and filler cap, does he want
another hose that runs from the filler cap to a catch can with a
breather?
As the blow-by worsens, it seems to me there can be a fair amount
of air movement.
breather?
of air movement.
Thanks guys, how do I check the PCV valve?
I did notice it doing this many months ago at another autox, but haven't seen it since. This car is more of a daily driver for me. I put about 10k miles on it a year. I've put a hard 10k on it since I noticed the blowby at an event last year. This event was mainly very high rpm first gear and very low rpm 2nd gear. I'm out of practice something fierce, so I was bouncing off the rev limiter in 1st a lot. Oil was around 250 degrees, I tried to not let it get hotter than that. Oil pressure seemed low at idle, I'm guessing because of the heat.
- Remove the PCV from the valve cover while engine is running.
Place a finger/thumb over the end (hot) to check that there is
vacuum. - With engine stopped, shake PCV and listen for a rattle indicating
that the check valve is free to move. - Remove the PCV from the hose and apply a small amount of pressure
from the hose end. Don't use your mouth. Check that the PCV is
sealing against backflow.
Location: If you don't weigh in you don't wrestle Road America
Not to come off as a smart a$$ but START USING 2ND GEAR!
I watch people all of the time in my Corvette Club running events in 1st gear thinking that they are really hauling a$$ but they are in reality slowing themselves down. It is much harder to control a vette in 1st since you will be reving very quickly and the back end will be hard to keep underneath you. Even if your lugging at 2k in 2nd the torque will pull you through. I did the same thing when I started autocrossing and I can't believe how much faster I was when I started using 2nd. Now I've won 2 NCCC Midwest regional championships in a row. Slow down to go fast!
Just some friendly advice that helped me a bunch.
Received 8,929 Likes
Unless it is a very short tight autocross course use 2nd gear as soon as you get a place to shift and do not shift back. Quicker times, easier on the engine and you will look so smooth.
Bill
Thanks for the advice, I'm just outta practice. I got 2nd overall, so I'm doing okay. The one 2nd place run netted no rev limiter. This course was the tightest one I've done, it definitely wasn't a vette club course.
So anyway, does the PCV valve just pull off? I tugged on it a little and it didn't wanna budge. What's the easiest way to remove it? Do I pull both ends off or just one side? Is the PCV valve on the left side?
Thanks Slalom.
Thanks Slalom.
