C5 Bushing Options...
What are the available control arm bushings for a C5? I know of 'Vette Brake Products' poly bushings, but that's all I've really seen. Are there Delrin bushings out for the C5? Have any of you tried them? How is the noise? How long do they last? How bad is the install? Etc.
My car still gets ~5k street miles a year but I don't mind suspension or road noise (my '99 Z/28 had heim joints throughout and that did not bother me).
Thanks for any help!
-TJ
-TJ
Originally Posted by John Shiels
found ### 408-295-9300 winter project for me
-TJ
THE VPB kit is suppose to be the best and most complete kit, but is the most expensive.
Oh it will be noisy...I don't love the noise, but I can live with it as well, I'll just never be able to sell the car to a normal person.
-TJ
I called I thought they were Delrin but they are poly bushings like the VBP bushings. Delrin as I know it is hard like the Hardbar shift *****. That is what I thought it was not poly, that I already have.
Originally Posted by tjZ06
I've heard from some the VBP "poly-graphite" bushings aren't all that bad. But like you I don't mind the noise anyway. I'd just rather go all the way and do Delrin if it's feasible.
-TJ
-TJ
You guys think the VBP bushings are expensive, wait until gives you a price on a complete custom built delrin set, I've already heard and it is going to scare you BIG
VBP Poly-graphite GP anybody?
-TJ
1 Post
Cruise-In II Veteran
The VBP set is a ridiculously good deal. I have no idea how they sell it at that price. Obviously Hardbar could do a Delrin/stainless bushing kit but it would cost at least 2-3x more. Delrin is very hard and would be inevitably noisier no matter how tight the tolerances are. C5's and C6's need to have spherical components so it would consume a lot of CNC machining time (time=money), since there are 16 bushing sets per car.
call VBP they will know or look at the online catalog
Their online catalog is not very user friendly, and doesn't state whether or not the item is for a stock C5, Z51, Z06, etc. Just has different sizes. 25mm, 36mm, etc.
doubt you will find that many people interested to make a GP and it is a small item.
Even if we save $10 people start to come out of the woodwork for these things. Never hurts to try.
Delrin has very little/no compliance. It will not work well simply because of the way alignment is done on these cars. For example when the arm is not square in its mounts like when moving the rear eccentric outward to gain negative camber or some positive caster. If the arms were moved equally at the front and rear bolt and totally square it would work, but then there would only be a camber change. In the rear arms only one eccentric is used for this and that would pose a problem with delrin. There is a modular design possible, but no one is producing it right now. Beyond the VBP one would have to install monoballs for any further benefit at this time.
-V
-V
1 Post
St. Jude Donor '07,'13
Group Purchase - Sway Bars
Hi,
Sorry for the delay, just sent you an email responding to the group purchase. For 1 to 4 kits 10%; 5 to 9 15%; 10 to 20 20%. Let me know guys. The price has to go up when my stock runs out. The metal for the sleeves has just doubled. Price now is $249.95 list, but soon will be $299.95 per set.
This is the sway bar info. I have:
'97-05 Fronts - 23mm FE-1 or F45; 26mm Z51; 30mm FE-4, ZO6,
Z51; 32mm; 38mm T1
Z51; 32mm; 38mm T1
