sparco steering wheel?
Old 09-03-2006, 11:05 PM
stickystuff
stickystuff's Avatar
Default sparco steering wheel?
thinking of replacing my wheel in my zo6.
are you guys running 330mm wheel?
what hub adaptor are you using?
Old 09-04-2006, 12:14 AM
sleeper02Z06
sleeper02Z06's Avatar
I am using a Momo hub adapter.
Purchased mine here ---
www.subesports.com
Go to steering wheels, then momo, then to hub adaptors.
Some minor plastic trimming is required to install, nothing big though! And yes, I run a 330mm Sparco wheel.
Joe
Old 09-04-2006, 12:22 AM
stickystuff
did you order the tilt version? they say 84 and up. im guessing that is thecorrect one?
Old 09-04-2006, 01:49 AM
HeyFred
HeyFred's Avatar
This is the kit I am going to install this winter:
http://performance.accuratetechnolog...products_id=89
Steering wheel:
http://www.sparcousa.com/psteering_comp.asp?id=278
Old 09-04-2006, 09:38 AM
RAFTRACER
RAFTRACER's Avatar
ATI stuff is top notch, removeable coupler is sheek too........I use a Sparco 350mm steering wheel with removeable couplers on both of my cars............Dont like the radically smaller wheel, tends to make steering inputs a little choppy.
Old 09-04-2006, 10:26 AM
Kschwamy
Kschwamy's Avatar
Danny sent a PM
Old 09-04-2006, 10:52 PM
stickystuff
anyone know of any other hubs? dont want to spend the money on a removable wheel hub.
Old 09-05-2006, 03:14 AM
sleeper02Z06
Yes, that is the one that is on my car. And it should be substantially more affordable than any quick-disconnect adaptor.
Joe
Old 09-26-2006, 02:17 PM
Drew Manzella
Drew Manzella's Avatar
Anyone have any idea whether or not that ATI quick release will work on a C4? A basic logical deduction says it will (Excluding the little cover piece) since the Momo wheel adaptor is listed as "84+" which leads me to believe that the dimensions, measurements, splines, etc of the steering shaft are the same from 84 on up.
Old 10-01-2006, 09:41 PM
stickystuff
will you have turn signals, tilt, windshield wipers, etc. using the ati or momo hub.
Old 10-02-2006, 12:49 AM
sleeper02Z06
With the Momo, yes. I have it, and have everything. Don't know about the ATI, but I would guess yes.
Joe
Old 10-16-2006, 11:04 PM
stickystuff
recieved my momo #2702 hub the other day. it is just a big hunk of metal. is this correct? no extension or rubber boot come with it? i want to confirm before installing.
also do you need to purchase a 2" extension to have the wheel in a proper position. seems like the wheel will be even closer to the dash then it is now.
last question is there anyway to re-hook up the horn?
thanks
Old 10-17-2006, 12:19 PM
stickystuff
Old 10-17-2006, 04:42 PM
sleeper02Z06
thanks
PM'ed ya!
Joe
To sparco steering wheel?
Quick Reply: sparco steering wheel?
