Remounting fuel vapor tank
Old 09-12-2006, 11:16 AM
danswofford
danswofford's Avatar
Default Remounting fuel vapor tank
I'm welding in a 4pt cage and on the right side the main hoop down tube welds into the frame just to the right of the right gas tank. Unfortunatly there is a fuel thing there. Yup, I don't have a clue what to call it. It has several fuel lines going to it and a small plastic tank. I need to relocate it. I'm thinking of putting it in the right wheel well above the rear brake vent opening.
Questions: What is it, and is it directional? In other words, can I mount it orientated differently. Stock it is mostly horizontal, I need to mount it vertically. All the hoses would have to be extended. Anyone foresee any problems with this giddyup.
Dan
Old 09-12-2006, 12:52 PM
XPC5R
XPC5R's Avatar
I think it's the charcoal canister, (scrubs the fuel tank vapors, then feeds them back into the intake tract). If mounted veritical, is it possible to have all the connections facing up - to keep liquid fule from pooling in the lines.
Old 09-12-2006, 05:48 PM
99BlackZ51
99BlackZ51's Avatar
It is the vapor canister, when they put my cage in they shortened it a bit.
Scott
Old 09-12-2006, 07:10 PM
DALE C
DALE C's Avatar
I would remove it and turn off the evap codes. Just make sure and run a good safe tank vent
Old 09-12-2006, 09:32 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
just plug it and seal the lines at the engine. They are the flexy/wavy lines going into the side of the intake.
You tanks vent through the fuel cap, although only just a little. The EVAP system holds excess fuel vapors from the tank, and the engine sucks them in and burns them.
Old 09-12-2006, 10:38 PM
danswofford
thanks,
Dan
To Remounting fuel vapor tank
Quick Reply: Remounting fuel vapor tank
