LS7 oil tank Capacity?
Old 09-14-2006, 09:20 PM
DALE C
DALE C's Avatar
Default LS7 oil tank Capacity?
Does any one know the actual capacity of the LS7 oil tan when at the full level on the dip stick? I know the total capacity with filter is 7.5 quarts minus the filter but it is not a true dry sump pan and I dont know how much oil is still held in the pan.
Thanks for any help, Dale
Quick Reply: LS7 oil tank Capacity?
