C6Z06 Active Handling question
Old 09-16-2006, 11:40 PM
hoefi
hoefi's Avatar
Default C6Z06 Active Handling question
Took my C6 Z06 to an autocross today.
After one run, the dash says "active handling recalibrating". I left the ignition on and waited. Message wouldn't go away. Decided to shut it down. Restarted engine for the second run. Message stayed on. Message remained after the second run. Restarting the engine for the third run, and everything returned to normal.
Is this normal?
Old 09-17-2006, 06:01 PM
joemoia
joemoia's Avatar
You'll probably get more responses if this question is posted in the C6Z06 section
http://forums.corvetteforum.com/forumdisplay.php?f=100
Quick Reply: C6Z06 Active Handling question
