All AutoX I need help
I started racing AutoX it is fun my problem is that cars with less HP are beating me. Am I at a disadvange because I drive an A4 all these cars seem to be manual. I seem to be the only American out there. Should I Drive in 2nd gear because it seem like the car is always try to downshift on its on which puts me to fast for the next gate or turn. Newbi AutoXer need help
1. Lessor powered cars are beating you because, right now, all the drivers are better than you. Autox is one type of racing that rewards the driver much more than car mods.
2. Read the sticky post at the top of this forum. There's a ton of info in there, probably answering all of the questions you have right now.
3. Have fun! No one doing this is trying to make money!
Have a good one,
Mike
Have a good one,
Mike
starting out is not kind to your ego, but VetteDrmr is probably right, at this stage, it's you not the car. Some of the guys in "lesser" cars have probably been doing this 10-15 years. Just stick with it, learn as much as you can and eventually, you're time will come.
Have a good one (and wecome to the asylum!),
Mike
the biggest thing to keep in mind is that the right pedal does not hae to go all the way down and it is reeally important to learn to brake early. it is the original slow in fast out sport. find someone who is good and preferably drives a high hp/rwd car and get his or her advice, ride with them, and have them ride with you.
You might want to try evolution school school too
I think the question was: should I drive in second gear with an A4 trans.. Good question, I have been trying to figger this out myself..
Have a SM2 C5 preping for BP with mn6 and 3.42.
just finished building a salvage C5 vert stocker with an A4 and did an autox before it was really finished and found when left in 2nd it would not downshift when you powered out of corners..The only time it would downshift good on its own is when I leave it in OD or shift it yourself..
I have since reprogramed a bit and improved the upshift alot but yet to improve the downshift... This is a '98 so your results may vary..
Joe
Joe
thanks guy your advice helps ALOT. I am on street tire (I run in street tire class) I tried running in 2nd (BTW I have a 98 Corvette A4) Its seem to come through turns find short straights seems slower to me. Alot nice people at events have taken me for rides and showed me were to improve this is my first year so I am hoping to get better.
Gerald
Gerald
