New front sway bar and noise.....
Old 09-24-2006, 09:34 PM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Default New front sway bar and noise.....
I just put on a 32mm front sway bar and really love the handling! One question though...
The noise that this sway bar produces is LOUD...is it the bushings or the bar itself? Can I get this noise to stop or to drastically reduce?
Thanks!
BTW: Also put Carbotech XP10s and AP Racing DOT4 fluid in...I am ready for the National Corvette Museum HPDE at Putnam Park and for Oct. 19-21 at Autobaun CC!
Adam
Old 09-24-2006, 09:43 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
what type of noise? Should be no noise
Old 09-24-2006, 09:45 PM
Adam Boca
Adam Boca's Avatar
when I hit a bump it sounds like metal to metal rubbing....
I have HEIM endlinks...Do these need to be super tight to where there is no play, or should they still be able to move a little?
Adam
Old 09-24-2006, 09:51 PM
Adam Boca
Adam Boca's Avatar
What do the sway bar endlinks need to be torqued to?
Old 09-25-2006, 04:56 AM
John Shiels
Adam
no preload with the car suspension loaded but not loose either. Look to see it is not hitting the A-arm on one side. Bar needs to slide and rotate freely but not be loose and well lubed. I havre 45,000 on mine and never heard a noise. Their are a few nicks in the paint where it contacted the a-arm a few times in all those miles.
Old 09-25-2006, 08:43 AM
Adam Boca
Adam Boca's Avatar
The movement is in the ball joints....Do they need to be greased?
Thanks!
Adam
Old 09-25-2006, 09:03 AM
John Shiels
Thanks!
Adam
ball joint have no movement unless they are worn out. I am amazed mine have not worn out after 45,000+ miles. I spray them with lube every so often. I just tighten the nut that holds the endlink never bother torquing it. Do you mean the jam nuts? That should not be real important either as long as they are tight.
found this
Definition: A flexible coupling in a vehicle's suspension that connects the control arm to the steering knuckle. A ball joint is so named because of its ball-and-socket construction. Some are designed to never require grease while others should be lubed every six months. As the joint wears, it becomes loose. The result is suspension noise and wheel misalignment.
Old 09-25-2006, 11:07 AM
wtknght1
wtknght1's Avatar
I've always heard some 'clunking' after installing the T1 bars and adjustable heim links, but that's normal for those. I've never heard any 'scraping' though. John's probably right...make sure the sway bar is not contacting the lower A-arm. Those adjustable links should be adjusted up high enough where they don't cause the bar to contact the arm.
Old 09-28-2006, 08:04 PM
Z06cool
Z06cool's Avatar
I just installed a GM T1 swaybar kit with it's metal endlinks and new bushings. The shop applied some Sabesto silicone lubricating compound on the bushings both inside and out. I like the tightness but hear a squeaking noise in traffic. Nothing if I'm going at constant speed. Still researching this but any help getting rid of that noise would be appreciated.
Old 09-28-2006, 08:08 PM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
Adam,
What year car do you have? The heim ends are very loud when you hit bumps. Give me a call and fill me in on what you have, I have been thinking about getting down to the museum again.
Justin Abbott
Zip Products
John Shiels
Not sure on the newer kits but I think you need to have 2-3 washers to shim the bushing clamp out from the frame or it is to tight. Bar should be snug and able to slide and rotate not crushed. There should be no noise or squeaks.
I never heard a noise in 55,000 miles
Old 09-28-2006, 08:22 PM
Adam Boca
Adam Boca's Avatar
I have metal endlinks that should be here on Saturday. Hopefully I can get them on soon and fix the noise problem.
The bar I purchased was used and came with the HEIM endlinks and on eack side they have the washers. The bar rotates freely, so I do not think the bar is hitting anything, so it must be the endlinks or the bushings...
I will call you tomorrow Justin. Can you PM me your direct phone number or extension?
Thanks!
Adam Boca
Old 09-28-2006, 09:22 PM
SFVetteman
SFVetteman's Avatar
Try using lithium grease in the bushings. I used an aerosol can of it that I have laying around to use on door locks, hinges, etc. and sprayed quite a bit of in the bushings when I installed the bars.
My bars make no noise now but they did initially because the way I had the adjustable links set up, they were putting a little preload on the suspension as well as positioning the bar too close to the lower control arm.
Old 10-03-2006, 01:35 AM
kelp
kelp's Avatar
Lift the car, then from directly underneath grab the bar and try to reproduce the noise. A small play in the link bearing caused mine on my T-1s. It was so unbearable, I returned to the stock link.
Old 10-03-2006, 03:19 AM
John Shiels
there should be mo play in the hiem or link bearing.
Old 10-03-2006, 08:26 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Heck, just go get the stock C6-ZO6 end links. They are solid aluminum and are silent.
Old 10-04-2006, 04:27 PM
Sully C5
Sully C5's Avatar
I use LGM links on my T1's...no noise.
To New front sway bar and noise.....
Old 10-06-2006, 08:53 PM
Z06cool
Z06cool's Avatar
I bought some lithium grease to try but then got a reply back from GMPARTSDIRECT which suggested I use graphite lubricant. I bought a small tube and it came in a black powder and kinda makes sense now since the T1 bushings have a meshed fabric inside which I assume is for holding that graphite residue better. Anyway, bushing squeak is gone now I just hear a little chatter from the endlinks that I didn't hear before because the squeaking was so loud ...but much better than before.
Old 10-06-2006, 09:50 PM
ICaughtVetteFever
ICaughtVetteFever's Avatar
Are they any better than the C5 aluminum ones?
Old 10-06-2006, 10:43 PM
Adam Boca
Adam Boca's Avatar
I got all metal endlinks and there is no more noise!!!!
Quick Reply: New front sway bar and noise.....
