C4 Guys - Need info on seat mounts
Did a search and came up with a ton of C5 info but not much C4.
I will be building a 96 for BSP as well as open-track. The car will have shared drivers for autocrosses and the 2 of us are very different sizes so it will be necessary to have 2 seats that can be changed quickly (ie: sidemounts) as well as adjustability front to back.
I see several slider options for C5s. Does anything like this exist for the C4s? I have been looking for several days but haven't found much. I am not against fabricating something if I have a definite starting point to work with such as the ability to modify stock manual sliders for the task.
What are you guys doing?
Also - What Sparco seats are known to fit in a C4? Which don't?
I use Kirky seats in both sides of my C4. I bought Hardbar mounts on the drivers side, but they are kind of pricey and I am cheap On the passenger side, I went to Lowe's, bought some 1 1/2" square tubing that was perferated on all sides. A little fabricaton gave me a tube that slid down over the stock seat mount bolts that I could bottom mount the Kirkys to. No adjustability, but if I understand you correctly, you are going to be changing seats when you change drivers. With the mounts I describe, you could pull the four nuts, move the seats foreward or aft to other holes and then put the nuts back on. If you get to the Charlotte area, look me up. Will be glad to show you.
I didn't see mounts for a C4 listed on their site - only C5s. Did I miss something or is there an unpublicized fact that the mounts work in either car?
I will most likely rigid mount the passenger side seat as It has no reason to move.
I had the Corbeau Forza seats in my C4 and I bought the Corbeau seat rails. They move fwd and aft and are just like your standard sliding seat rails.
Although, they will not be very easy to quickly change seats. You could get a Corbeau Forza II which are made for guys 220 lbs+.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
He's got the seat rails.
